Tire Carrier Pivot
bigbluesuburban
Constant State of Perpetual Anger
I am building a tire carrier for a buddy. I want to use a greasable spindle type pivot point and I am wondering if anyone knows where to get the whole assembly already machined and ready to weld on. I looked at DIY4x and he has great tube bumpers but I want to build my own but without the machine work.
Any suggestions
I used a RockStomper spindle on a bumper I built for my last 4x4 (Jeep Cherokee :doah: ). It was a good product.
steve
I always thought it would be cool to get a spindle and hub form a 10 bolt and use the locking hub to secure the swinging. just weld the spnidle to the bumper with part of a stub shaft welded on the inside.
OHHH ^.^ I read a bad review on the rockstomper spindle. http://www.sonoransteel.com/rearbumper.html
Broken Spindle in left pic and Cracked bearing races 2nd pic
"After 1 year the metal in the trailer spindle fatigued and failed. DO NOT use a Rockstomper hinge. One failed on a Tacoma in Southern California as well in the exact same manner. "
I do not and have never used any of this guys stuff just what I have read in looking for my bummper.
I have one of the rockstomper units, and it's great. Cheap too, and he gave me a lifetime warranty
Someone on this board did just that, but without the locking hub/stub shaft, there were pics and all. I suggested the stub and locking hub so it could be held open. I don't know if he ever did it.
cbbr said:
I used a 1" grade 8. After everything I read about the Rockstomper hinge, I just didn't trust it.
Ok more details on how you did it in detail. Yours looks like a good one and I am going to be reworking my bracket this winter so I might just copy yours if you dont mind.
Copy away. The bolt is a 10" long 1" grade 8. It passes through 4 sections of 3/16" steel (2 sections of 2X4) and there is a nut welded in that it bolts into.
The piviot is a 3/16" gusset capped with a bent piece of 3/16" plate. That gives it two contact points which keeps it from wobbling. I used flanged bronze bushings where the bolt cotacts the bumper which keeps it smooth and tightens the tolerances.
The other side is held down with a 9/16" grade 8. I welded a nut into the bumper and built up around it. Its simple, but very tough and there is no movement to cause the bolts to sheer. I weigh 200lbs and I climb all over it.
The only PITA is the fact that I have to usea socket to undo the "swing" side, but I just keep it in the console and I don't open it very often.
I am going to pickup a 1000 or so pound trailer spindle and hub from the trailer shop. About $30 total then cut the wheel mount surface off the hub and then you have greasable bearings.
