In my experience, the reason fronts wear that way is that they experience braking force only. The tread blocks deform slightly when braking, wearing the front side of the block more.
Imagine dragging a stick on the ground, it doesnt stay pointed straight down, as you move forward it wears more on the leading side.
They show it more on the sides because the tires lean slightly when turning. Ackerman angle has an effect also.
Rears don't do it because they see both directions of force due to acceleration forces as well as braking. Now this is only on a rear wheel drive vehicle, front wheel drive tend to do it to the rears instead.
