tire pressure question
big83chevy4x4
3/4 ton status
Sheridan, Michigan
right now i have 265/57x16s mounted on 16x7 rims and i run 65psi (rated) on the street and 10 in the sand and about 15-20 in the mud/trails.
i got my 35x12.5 mounted on my 15x10 8lug rims /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
i know that with a bigger tire the tire pressure changes.
i can always play with the offroad pressure, but the street eats the tires too fast is there not correct.
what pressure do you think i should run on the street? sand? mud/trails?
For street run what is recommend on the sidewall.
for sand run as low as you can with out blowing the bead
and for trails/mud run around maybe 20psi /forums/images/graemlins/dunno.gif
On the 35's I would keep them around 30psi on 10" and 25psi on 8". I work at a tire shop (DTC) and we have pain in the azz to read charts that cross this as best. I have also personally run 35psi, 30psi, 25psi, on both 10" and 8" as well. I find the above to be best for my application. Just don't load the tire down when it is below 30psi as it will heat up real fast (BOOM). The 35's are probably max at 35psi to begin with.
my Michelins recommend 80psi on the sidewall
no thanks
they ride rough enough at 40psi
they ride great at 24 psi but I am chicken of wearing them out down there
hard to find them again
any distance driving you need higher air pressure
local stuff you are not going to overheat the tire
now how often do you wanna air up n down?
an IR temp meter would be cool to play with in chacking tire temps at various pressure
Don't know about narrow tires like 12.50 but with my boggers I just inflate them to 30 psi and start letting air out until the tread just starts to sit flat across the cement floor for best wear.
what makes you think that will wear 'best'?
'most even' yes, but maybe 'fastest' also.
Skinny tires are the same. Make them run flat across the ground.
its on my DD, so i drive on the road quite a bit. to play in the real stuff (not "dirt roads") i have to drive at least 1.5 hours, the next nearest is 2 hours the other way.
i air up/down aprox every two weeks-a month.
so you think 30psi on the street even with the bikes in the back? most weight i put in the back is about 1500 lbs (my cr500 (240lbs) my dads xr600 (350lbs) and my moms xr200 (220lbs) 3 people, gas and gear) and drive 2 hours.
30 should be fine for that. Look at the side wall raiting on the tires for weight and multiply that by .85 <- (30/35) that is roughly how much weight they can handle at that pressure.
[ QUOTE ]
[/ QUOTE ]
You are probably going to go into some long speel about how I'm wrong but I have heard from a lot of people and from my experience is that with a wide swamper having all of the tread width on the ground promotes the best and longest wear because they are not riding on the center of the tire..at enough PSI of course.
[ QUOTE ]
[/ QUOTE ]
mj check the air pressure "hot" if they go up 10% or more you need more air.
i run 60psi on road, 10psi off, i could go 0psi (beadlocks) but i havent needed it yet
Okay, running my K5 for an hour and a half at 70mph put the warm air pressure up to 30 psi (started at 25psi cold). I use to run them at 35 psi (max) and after driving the same road in the same conditions it would be 40psi warm. Doesn't really phase me. I have been doing it for 2 years now and no problems to speek of yet.
For long highway runs I used to run the Swampers at 25 PSI.
Usually 20 for in town and highway runs 1 hour or less.
Now they never have more than 10-11 PSI in them as the rig is trailer trash.
[ QUOTE ]
[/ QUOTE ]
The pressure listed on the sidewall is not a "recommended" pressure for everyday driving....rather it's the maximum allowable pressure for the tire when it has the maximum load on it.
In the original post he mentions the sidewall says 65 psi on a 265/75R16. Based on this I'm guessings it is an "LT" tire with a "D" load range, and therefore probably has a load rating of at least 2,500 lbs. per tire. That means that all 4 tires at max pressure can support 10,000 lbs.......your truck obviously doesn't weigh anywhere close to that much when empty so there is no reason to run that much air pressure. Running too high of pressure will cause a rough ride and will wear the center of the tread.
Just as a quick fact regarding larger tires requiring different pressures.......it's the VOLUME of air in the tire that determines how much weight it can support, not the pressure. That's why a larger size tire requires less pressure to support the same weight.
muddytaz put up a post a few months ago that covered this issue really well. I followed what the article said and my tires have worn excellent. Very even and very little wear. If you PM him he may still have the link to it.
this i can agree with.i used iterco's recomendation and they wear to fast in the center(boggers that is).one thing i will say is boggers can hold some serious weight. i carry between 2200lbs and 4100lbs in my DD all the time.and aired up to 25 pounds each they don't squat at all. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
