I had run across this stuff awhile back. https://renew-pro.myshopify.com/
With tires as expensive as they are, and me getting maybe 15-20k out of a set before the rubber starts to obviously deteriorate, I wanted to see if I could do something to prolong their life. As I understand tire design, actually using them (instead of just sitting) is best. Mine sits a lot.
The D3 product linked above I believe is essentially Cerakote, which is pretty commonly used on things like black vehicle plastic that is sun faded.
I don't necessarily buy into marketing stuff, but for the price of trying the D3 product, and cost of tires, it seemed to be worth trying.
The truck is going to sit outside for the next 9 months or so, not driven. Not a ton of direct sun exposure but there will be some, plus lots of rain/humidity. I took pics so I can compare at the end of that time.
As you can see, I did minimal prep. Hosed the tires off, let them dry, then applied. More prep and more coats definitely darkens it up. Limited time, limited effort lol.
I painted the "stripe" to get some contrast against what the tire looked like to start. That had dried overnight. I had already done the tread which is why thats darker.
I think these tires are five years old, in person I didn't see any flaws in the application, pretty sure anything you can see that looks like a flaw is the tire itself. Again, I expect from lack of prep.
This is maybe 10 minutes after application. If I was going to do it again I think a spray bottle or a pan to rotate the tire through would have gone MUCH faster (and done a better job) than trying to dab it between the tread blocks with a paintbrush. Invariably you miss places since you can't see all of the nooks and crannies. Product has the consistency of water, flat surfaces (sidewalls) were super easy and fast with the foam applicators.
Does seem to stain. Not so much skin, but the cardboard I put under the tires turned dark black when I dropped some on it.
I got the "Blak" 16oz kit. Came with a foam brush, foam block, microfiber-ish covered foam applicator, and a baggie each of prep and vinyl protectant fluids.
I used maybe half of it on the 33x10.5's, so seems to go pretty far. Now if it just works. Not sure what I'd expect to see in that time, but I didn't see any cracking yet, so if none develops, I suppose that may be an indicator it works.
