Tire Size question
Bruiser
Portland, OR
So uhm, would it hurt anything to run different size tires, front to back. I know Side to Side isn't good.
I have 3 32's , tring to find a 4th, but a guy has 3 33's.
Vince
Not a good idea overall. For starters, you can't put it in 4WD, you will break something as the axles are trying to turn at different speeds. And brake balance will also be affected. I would stay away from this plan.
As long as you keep it out of 4wd front to back tire size isn't that big of a deal. 32's up front 33's in the rear. I usually put bigger tires in the back of my 2wd stuff, don't see why it would hurt as long as your hubs are unlocked. :wink1:
Took it to the tire shop. They took it off, cleaned the rust off the rim and remounted. Holds air fine now. Suprising how much better a truck looks with nicer tires. :P
