Tire spec help q's?
Fancy
Reno, NV
So i am working with Trail Worthy right now to get some PVC inserts for my H1's. I want to run the military 37"s for my DDing and then swap in some TSL's for the off road use. But Andy at Trail worthy says the TSL bead thickness is often a lot thicker. and the PVC's need to be cut down. So i am trying to find specs on the TSL's i am looking at to see if we can find a median that will work for both sets of tires. (already tried contacting Interco with no luck but i will keep trying.) Below is a list of the tire options i am looking at in order of most wanted for my ride. So if you have a set and could measure the bead thickness it would be greatly appreciated.
Sam-55r (38x15.5X16.5LT) radials
Sam-35 (15/39.5-16.5LT) Bias
Sam-24 (15/42-16.5LT) Bias
Sam-71 (15/39.5-16.5LT) Bias
I will post up a picture later of how to measure bead thickness correctly if anyone needs it.
Thanks For the Help
