I have inner tire wear on my 85 cc 1ton 4wd. Is this correctable if I put a mild 2-3" lift on it? Also what is the largest tire I can put on the a stock front dually rim.
thanx
inner tire wear would probably just be toe out. could possibly be camber, but a simple alignment will correct it. a lift should do nothing to alignment, except affect the caster.
