Likely candidates are tie rod and drag link ends, ball joints, spindle nuts. Easy to diagnose:
Jack front end up under axle. Grab tire at top and bottom (12 and 6 o'clock), wiggle. If it moves up-and-down noticeably, think loose spindle nuts or worn out ball joints. (You said you did the wheel bearings, so you know about the tighten until they drag, then back off a smidge and set the outer locking nut thing?) Worst case take the tire and brakes off again (sucks, I know). If you can move the spindle so the knuckle moves, get thee to the parts store for some Moog ball joints.
Also grab the tire on the sides (3 and 9 o'clock) and wiggle. If it moves side-to-side, think steering (drag link or tie rod ends). These you work through one at a time -- try to move them by hand. If they have any slop, that's bad. (Note they may turn a bit, that's okay, but if the end moves at all inside the ball end ... like a mortar inside a pestle, say ... that's bad.)
Also depends on what you mean by "wobble" ... could be brakes, i.e. pads not seated, warped rotors (I know you said they're new, but it happens) ... but if the wobbling only occurs at the ends of the steering arc I'm inclined to suspect steering more than brakes.
-- A
