JW-Tex
Registered Member
1973 K5 got it running added new carb replaced valve seals. The 305 is tired and appears to be from the 80s has a bunch of crude under the valve covers sludge and hard black deposits. The compression is good but still smokes a little on startup.
Have been considering a crate 350 but cost is high. Have run across a 454 in an RV with 45,000 miles. I can get the running 454 for $600. If I got the 454 would put all new gaskets , new oil pump, new water pump etc, probably add new carb and headers. End result probably have $2,500 in the 454.
Any input on reworking a 454 versus crate 350?
