84_Chevy_K10
Banned
Fierospeeder said:my friend has a fast boat. It has a chevy small block with a "carb"
My buddy has a fast boat too. It's got a top fuel engine in it.
No carbs there.
No carbs there.
dirtwarrior17 said:I can understand you defending carbs because you run one but what are you trying to prove? YOur buddy runs a carb on his boat... whats your point? EFI is better hands down...more expensive but better.
Dirtbikes have been coming out with 4 strokes for the last 5 years(in motorcross) and they have an unfair advantage from the extra cc's. for example 125's run with 250 4 strokes.... thats double the cc. Then you look at 250 2 strokes vz 450 4 strokes... If it was really fair they would need to apply the same rulz as the 125 class and double the cc's of the 2 stroke. That is the WHOLE reason the 250 two strokes are still kicking the 4 strokes asses and the 125 two strokes are getting their asses kicked(even thought the last championship was won on a 125.... just because stewart was riding it tho.) But that has nothing to do with efi. Dirtbikes already cost 6 grand new... they run carbs for the cost, not because they prefer them.
Carbs have been around for decades and there are a lot of people that know their way around em becuase of that.
A narrowband o2 only means the level of gauging is limited it has nothing to do with accuracy. a wideband might measure 10.0 to 18.0 and a narrow might measure 12-16 but they are both equally accurate when the readings are in the band.
If you ask me, you are the one that has a lot to learn about efi...not trying to start **** just my opinion.
1991 GMCk2500 4x4pu. Has anyone here swapped over to 4 bbl from tbi? This seems the best way to go for the best and cheapest hp gains. This is what I have in mind to get to 300hp from the stock 200. Vortec heads ($500), intake ($250), 600 cfm 4bbl ($300ish), an rv type cam ($200). Just looking to hear from someone who has done it before I go it alone. I also think that my truck cant get much worse gas mi than it doeas now--11mpg. It is all orig w 98K and runs beautifully. thanks
Fierospeeder said:the boat thing is towards "thunder" and no one else.
If you knew how an engine work. You would know the difference between the power a two stroke makes and a four stroke. That is why a four stroke needs a "larger" engine to compete with a two stroke. It maybe due to one engine having more power strokes then the other. And btw, four stroke dirtbikes have been around way longer then 5 years. I am refering to EPA rules of stopping production of two stroke motorcycles all together. You dont see two stroke street bikes no longer in production. They were quick as hell.
for the oxygen sensor. heres a website with the graph i was refering too.
http://www.turbosaturns.net/articles/oxygen%20sensors.htm
notice they mention "accuracy"
I can quote you about not knowing how to diagnose efi. Something about resetting a tps by pressing the gas pedal.
http://coloradok5.com/forums/showthread.php?p=1149078#post1149078
People with the fast boats are nuts. Might be as much as the top fuel guys. I have seen too many vids of guys in the boats hitting a wave and the boats go flipping in the air. Then they come crashing down like a RC airplane made out of balsa wood.
I would think my service manual would tell me to press the gas pedal?On 2.5l engine, the TPS is not adjustable. The ECM uses the reading at idle for the zero reading, so no adjustment is necessary
91GMCSuburban said:I do agree with this and would do and have done the same thing. But since I've been there, I now what's coming.
Check vacuum lines, clean tbi (maybe even rebuild) and clean the injectors.
Also (and this is not likely because it would be a free fix), reset the TPS. Unhook the battery to reset the computer, once reset, turn the key to "ON" and then press the thottle pedal from zero to full throttle 2 or 3 times. If it had been replaced and not reset like this... you may get lucky.
well, with outboards. you mix a certain ratio of oil to gas. you pour it in the gas tank.
Same thing with jet skis.
origianally posted by dirtwarrior17: How do you explain 2 stroke jet skis and outboards?
