right now im running a 4" shackle flip and zero rats in the rear... my question is, should I get 2" springs, and keep the flip, or, just go with 6" springs?
Are you using the Zero Rates to move the axle? If not, you could always replace the Zero Rates with 3" lift block as a cheap route to get what you are wanting.
I'm definately going to need the zero rates to move the ale if I go the 2inch spring route with the shackle flip. As it sits right now, even the most minor flex and the rear tires are rubbig my quarter panel, because I put them in the middle of the zero rate.
For six inches of lift in the rear, I'm running DIY4X flip, 4.5" shackles, and 2" springs. I'd take that combo any day over 6" springs for ride quality.
