Toywrecker
Registered Member
I've been searching around for answer for this problem with no real solid answers. I have an 86 M1028 CUCV I bought about two months ago, entirely stock with Copper 235/85/16 load range E tires I normally run around 70-75psi. When I first got the truck it began having issues. The truck would wobble from side to side at low speeds and would shake badly around 45-50 mph (probably 40-45 with my speedo the way it is.) At any other speed it would even out a bit. I diagnosed the problem as bad belts in the tire and swapped it out with the spare tire which solved the problems until a few days ago when it began having the same issue. I also had the truck aligned at Firestone before swapping out the spare, if I recall correctly.
When the problem happened again I took it to Firestone for a quick look. Nothing useful came of this other than I was told the spare that is bad is 7 years old! But apparently the other tires on the truck are 17 years old and wearing fine! By the way, I know cross rotating tires could cause this problem, but I have not put enough miles on the truck to justfiy a periodic rotation.
I also apologize for the long post. I wanted to describe the problem as best as possible.
) in addition to having the alignment redone (free) and the truck inspected (about $20 and who knows, they might find something I missed) I'm definitely going to air the pressure down to 40 or so. Most of the time all I carry in it is some basic tools, my hi-lift and various other odds and ends. If my leaves are messed up I may end up replacing them when I do my lift, possibly with a slightly lighter, flexier spring. I do like the fact that these trucks can carry close to 2 tons, but the pay off is they ride like buckboard wagons unloaded.
, Im pretty sure that is impossible as there is nothing to adjust. Also IIRC a tires shelf life is 6 years. You can get away with as much as 10-12 without any real problems normally but you are askin for trouble and i'd recommend new tires if at all possible. The tires on the burb i just bought are 04's (you can tell a tires age by looking at the last 2 numbers in its D.O.T which represent the year it was manufactured) and its so cracked to hell they wouldnt patch a hole in it at the tire shop i work in
