Titan Series Heavy Duty NP205 Rear Output Shaft
NorthWestFab
Canada Eh.
This is our New Titan Series NP205 Heavy Duty Slip Yoke Eliminator Kit. Fully CNC Machined in house from 8620 Billet Steel, Heat Treated to 58-62 Rockwell, then hard turned to exact bearing tolerances. The weak links of the stock 32 spline output have been eliminated by reducing the oiling groove size and increasing the shaft diameter for the bearing and the yoke.
Factory NP205 Rear Output Shafts like this one Break at the oiling Grooves
Our Titan Series Output Shaft (Center) has reduced oiling Grooves, Elimintated Speedo Gear and Increased Bearing size to make it the Strongest NP205 Output Shaft on the Market!
Our Titan Series NP205 Rear Output Shaft gives you the peace of mind that your output shaft will handle all the power and gear reduction you can throw at it!​
Included in this kit is:
1x 34 Spline Titan Series NP205 Heavy Duty Output Shaft
1x Output Bearing (Larger than Stock)
1x 6061-T6 Billet Bearing Retainer (Machined to Accept Larger Bearing)
1x Custom Laser Cut Bearing Retainer Gasket
1x Output Shaft Nut
1x Output Seal
5x 3/8 x 7/8 Socket Head Cap Screws
**Note: Machining to the Speedo Housing is required to accept the larger bearing**
**Note: This Output shaft has no Speedo Gear Provision for maximum material size!**
**Note: A New Yoke or Flange will be needed to fit the 1.75" 34 Spline Shaft. These are only available through us or High Angle Driveline**
This Kit Retails for $489
Use this Shaft in Conjunction with our New Titan Series NP205 BlackBox-i to have the Strongest 4 Speed Transfer Case Available!
If you have any questions or want to place an order please feel free to call us at 250-248-6024 or email us at [email protected]
Next Batch of shafts are currently at Heat Treating! We should have them back and Hard Turned in 3-4 weeks! Also watch out for the New Titan Series 34 Spline Front output Shaft Kit coming soon!
