Hey everyone!
Here's a new design set of lower shock mounts that I've come up with over the years, and finally decided to put them into production. I can make them to whatever axle tube diameter, and whatever angle you require. They put the shock bushing bolt perpendicular to the axle tube for better articulation and less wear and tear on the bushing itself. Designed for the stock rear GM shock bushing with the factory bolt (9/16" bolt, 1-5/8" wide)
Installed Pic:
ALSO,
Here is a simple Upper Shock Crossmember that requires you to drill two holes per side but effectively allows you to mount it wherever you want.
Installed pic (with only one shock installed though):
PRICING:
Lower shock mount pair: $45
Upper Crossmember: $80
Buy them together as a "kit" for: $120
Shipping not included. PM me to order until they are posted on the website!
-Darren
Installed Pic:
ALSO,
PRICING:
-Darren
