To those with the March P/S Bracket
NEK5
3/4 ton status
Ipswich MA
Did you use the nut/bolt as it says too for the lower mount on the waterpump, or just use a bolt that threaded into that hole?
The bracket on the front left of the pump is the one in question....
TTT!
New question. I can`t for the life of me get the bolt on the back of the pump off, not even my impact will get it off, which isn`t saying too too much. It`s supposed to be removed so that you could use the hole to fast the rear bracket to the pump. TIA!
