I just got my 75 up and running with the new powertrain: 2009 5.3L, 4L70E, and nP241 swapped in. I am getting some really bad vibrations around 70mph, I think the pinion angle to the rear differential is too steep.
I am curious, what did you use to mount the 4L60E to the cross member? I used the transmission mount that came off the 4L60E from a 2009 tahoe, but it's about 2" tall. What did everyone else use? something shorter would reduce drive shaft angle. I haven't changed the body lift since the original powertrain, but this drivetrain combo is about 6" longer with the advanced adapter, thereby increasing the angle from the transfer case to the differential.
Also, how easy is it to rotate the rear axle up?
thanks,
Brian
thanks,
Brian
