- Joined
- Apr 23, 2016
- Posts
- 2,937
- Reaction score
- 5,013
Hey Heath, I know it had a 205 on a th400 with a 10 bolt. I think 4” lift.What did it come off of for a trans/tcase, and front diff? What lift?
I don't have it assembled yet to measure, trying to see if it's even close.
This is a front shaft ya knowI may be in the market, but I wont know the specs until I rebuild the 241 and put it back in with the sye.
I must be missing something.Good to know. I was thinking it was a rear.
I’m sure it would. Only difference is the smaller dia. tube and 1310 u-joint. I know most of us are running a 1350-1450 on the rear axle.I must be missing something.
If it spec's out, why won't it work?
I'm running a very similar looking shaft in the rear of the Crawlabago.
Let me double check with @fourwheelerjeff he was first in line, then if he passes I'll get you setup.I have the money and need it
