79HeavyChevy
What are the common causes to get death wobble in a front end? I've got a 10 bolt front under my truck now and went through and did ball joints, bearings and joints about 2 years ago before I lifted it. Its always rode good on 32x11.50 then and on 35x13.50 after I lifted it. Tie rod ends have been on my to do list for awhile, but since I have swapped to a set of 38x15 it will get a death wobble ever now and then, and very violently. Looking under the truck yesterday it appears I have bent the front tie rod end upward on something but I don't know how long ago.
Also on a welded/spool'd front end I have read you need to "phase" the u joints but haven't seen any diagrams. Do they need to be on the same axis or 90 degrees off?
Maybe I just need a build thread to compile questions in....
