Ever sit back and think of all the projects you have going on with your vehicles and think you should have done one at a time
? Heres my list.
Decided i wanted to convert my K5 to TBI so I have TBI stuff all strung out in the garage
Then I found a Donor Rig with 3/4 tons so I pulled the axles and have them getting rebuilt. Halfway through decided to convert the 14 Bolt to Disc.
Realized I was losing my tranny so decided that if I have to pull the T case I might as well through in a rebuilt one as well...but why just rebuild a 205 might as well twin stick it
If I'm swapping axles now's the time to do a shackle flip and if I'm going to do a shackle flip might as well throw in some longer springs.
Oh then theres the Jeep...Flex fan was causing it to overheat on the trail, high RPM + low MPH= flat fan blades and not much air. Having a hard time finding a stock fan blade that will work with an alum. radiator
? Heres my list.Decided i wanted to convert my K5 to TBI so I have TBI stuff all strung out in the garage
anyway he just called and wanted to know what front axle I was swapping and I told him a Dana 44...He asked me why not a 60? Only real answer...finacial...I can't afford a 60
Apparently a buddy of his just scrapped one
My plans may change again
