joshkbomb
I had my transmission fluid changed last week and now the truck is shifting from 1st to 2nd harder than it did before. I tried to check the fluid level but it was on the entire stick (way over the full line). Is the hard shifting caused by the fluid level or is this just a side-effect of brand new fluid? I should say that the 'hard shift' isn't necessarily bad, just noticeably harder than before the change.
My mechanic checked it and agreed that it was a little overfull but said that it was fine. Is this true?
