ohhhh lube the top... will do as I think it be dry from all the cleaning..also lots of lube on the top and bottom slide areas so the caliper can move .
like said pry up against the upper and start the lower at like a 45* and rotate up and in .
YEeeeeeHaaa!
Just romped VVVVeeerrrrrummmm the neighborhood... now ready to test![]()
The crazy looking fender/paint is due to a garage fire that nearly not only killed my K5 but burnt my house down with us in it!
Burt
Measure the thickness of the 2 brackets.Wire wheeled them and the brackets and these are the ones that came on the axle. Probably the reman’d calipers. The old calipers didn’t have springs at all.
