verceingetorix
Registered Member
Black upper and lower Craftsmen Professional Series mechanic tool box. It is brand new still in the boxes on pallets. (Pictures are of a same model buta used box) It is 36" wide 70" tall and 21" deep total cubic inches is around 30,000. New it is $2,250.00 plus shipping and tax. I need to get rid of it I want $1,500
JMR Model 1003 Mechanical Bender
Includes
Mechanical Bender
1.5" die
Degree ring
Stand
JD2 TN-100 Notcher
Features
Most Leverage of any manual bender
Billet Dies available in 120 and 240 degrees
Aluminum bronze bushings at pivot points
Bearing supported ratcheting mechanism
Anodized black finish
Lightweight and portable
Built for industrial use and yet affordable
Lifetime guarantee against breakage on dies
Specifications
Will bend .250 wall 4130 Tube
Follower blocks case hardened .050 min
All pins made from heat treated 4140
2" Round Tube, 1-1/2" Square Tube,
1-1/2" Sch 40 Pipe Capacity
JD2 TN-100 notcher
Large capacity and low cost - The TN-100 notches 3/4" through 2" O.D. tubing at angles up to 50° in under 20 seconds. It uses commonly available bimetal hole saws costing approximately $10. A single bimetal hole saw will typically notch 3 to 5 complete cars.
Easy to use - The TN-100 may be mounted in a drill press or simply clamped in a vise and used with a 1/2" hand drill. The TN-100 can be laid horizontal when notching 45° angles, so the floor will not interfere with the tubing being notched.
Heavy duty frame - Entirely CNC machined, the frame is made from 1/2" thick 6061-T6 aluminum and its face has been milled flat. The degree increments are then machined directly into the frame so they can't wear off. An all position swivel base ensures easy setup.
Rigid bearing block - This is the most critical part of a hole saw style notcher. The TN-100's bearing block uses twin needle bearings and separate grease seals for maximum rigidity and reliability. A 3/4" ground and polished stainless steel shaft protects against the possibility of rust contaminating the precision bearings.
Strong, accurate tube cradle.
Tubing bender $1,500
Both items are located in Pocatello ID, 83204
1-208-234-1535 Bart
Includes
Mechanical Bender
1.5" die
Degree ring
Stand
JD2 TN-100 Notcher
Features
Specifications
JD2 TN-100 notcher
1-208-234-1535 Bart
