tool of choice for trimming fenders?
ryan22re said:
whats your tool of choice for trimming fenders?
im thinking sawzall/cut off wheel
I use the old plasma cutter and clean up with a 4" grinder if needed.:p:
yeah...you guys and your fancy toys...
i dont even have 220 yet and its been on my to-do list for the past 2 months.
or decent lights in the garage...
Drive it on over to my house and we'll drink a few and cut your **** up.:D I'm only an hour away, come on now if you want.:hack: :weld: :grind: :xmas:
considering it currently has no t case driveshafts or fuel tank, it might take me a while to get there.
did you ever find any dodge lockouts?
nope. Well, throw that stuff in and come on.:haha: I'll be up a few more hours. I've still got a case of beer to go.
cause my 60 has dodge lockouts on it.
id like to find a set of chevy hubs and such, but as slow as i move, id hate to promise them to you.
Heavy stuff with the sawzall, shaped the lines with a cutoff wheel, smoothed it out with a 4" grinder. It was pretty until I started bouncing it off of trees.
did the front tires hit the front of the fender by the marker light? i think our setups will be pretty close. i was thinking about going about 2 inches into the marker light. you have 52s right?
Well, I don't have 52's but the axle is moved 1.5" forward. When things compress the action of shackle moves everything back quite a ways so I don't have troubles except at full lock and full throttle on one side.
When the tire is turned away from the inner it clears by a ton. When the tire is turned towards the inner (because of scrub radius...I have 4.25" of b.s. by the way) the outmost corner on the lugs contacts slightly, I can hear tiny thumps over the motor and people have told me what's going on.
A picture of a tire stuffed and pointed away from the inner:
ive already lost my inners, and i am planning on a pretty serious fender trim. but the front is really the least of my concerns. those 63's are gonna make me cut a bunch out of the rear.
i am even considering notching the firewall to try to fit some 42's.
I'm running the 42s and 63s and I didn't end up trimming too much. I haven't done the front yet so no help there. I could get you some new pics in the morning of the 42s and 63 rear flex/clearance. Its pretty insane.
works for me.
did you resolve the tire clearance problems in the rear from your prev. post?
Gonna try bumpstops and if that doesn't help I'm just cutting the inside wall of the fender well and trimming a little floor. Hoping to leave the hump intack.
do your 63's have any arch to them when mounted? mine are damn near flat, only until i took out the back seat and the tailgate did they really start to show any arch. im guessing when i take the top and doors off the back of the truck will jump up two inches.
Very little arch. I'm using the 2" lowering shackles for height and haven't ran a tailgate, doors, or top in a few years.;)
ive got 52's up front with a zero rate, and in the back, a flip and switch, with 6 inch shackles, my 63's and had to add a 2 inch block to level it out. i really hate that block in there, but will have to do for now.
