I used to own an '88 1/2-ton suburban and thought I could apply that manual to my '91 3/4-ton. I had replaced the rotors, ball joints and bearings on that 1/2 ton and now have to do the same on the 3/4-ton. I still had the wheel bearing lock nut socket I used on the 1/2-ton and thought I was all set. Then manual for the '88 says that the same socket is used on both 1/2 and 3/4-ton vehicles. However, that is not the case in '91. I found the hard way that the socket does not fit the '91 3/4-ton. Can anyone identify the correct socket. I called some local parts stores only to find they are clueless. The 1/2-ton socket fits a 2 1/4" nut. So, I guessed and ordered on-line a socket for 2 1/2" nut. It is too big. A web search us unclear and let to my ordering the wrong one. No more guessing. I must ask the experts here. Your help appreciated. Thanks.
