ANY grease will "hold" dirt. It's a sticky guey substance, how could it not. It's just a drawer roller guide. Any grease will do, even you generic crappy ol' White Lithium grease, although I almost never use it for anything, but it's better then nothing. I use water proof grease on most things like this application. Maxima grease....not sure of the type off the top of my head, you can get it at motorcycle shops. I use it to seal my air filter to the air box, axle grease etc. It works well. Axle/wheel bearing grease will work just fine. You don't need hi-temp or hi-pressure though. I would not use motorcycle chain lube like the sticky stuff thats not suposed to fly off. It's really sticky and stringy. You could use the wax type chain lube.
