Hi & welcome!
Love your screen name!
Just a couple of thoughts if I may...
Lets keep in mind that you went from a 72cc cylinder head to a 64cc cylinder head which means you increased compression. Higher compression means its harder to light the fuel mixture in the cylinder therefore increasing the demand of your ignition components.
Granted we aren't talking about extreme cylinder pressures here like what would be made by boost or nitrous but none the less don't forget to check the basics.
How old are the wires and the coil on this rig? If you had wires that were going bad or a coil that was getting weak and you presented it with higher demands by adding compression to the mix you may have pushed the seconday side of the ignition to its limits if you are using older parts.
Just a thought but I'd check the seconday side of ignition things as well such as wires, coil, cap and rotor along with the other suggestions made by the rest of the gang like fuel, ignition module, etc...
-Phil
i have new bosch platinum plugs, accel 8 mil plug wires, brand new accel high output coil....new cap new rotor......thats whats leading me to believe the dizzy is the culprit....it does have a lil play in it....it will get changed this weekend.
