OK,I'm puzzled..been a long time since I had to bolt up a torque converter on an older GM...
I have a TH350 mated to a '70 307,someone removed the bolts that attach the converter to the flex plate...and lost them..I need to know how long the bolts need to be,and if the nuts are typical ones with a 9/16" hex or something different..
Far as I recall,they were just regular 3/8" nuts and bolts (grade 5 or 8) that I used on my 70's vehicles,but I cant seem to get a nut on the converter side to align with the hole on the tab welded to the converter...I do not recall the nuts being "special",or having to grind one side down to get them to line up in the past..and you cant insert a bolt from the converter side with the head facing the converter..
Anyone clue me in ?...
...I just want to see if the engine sounds OK,if not,I may just load it and the Th350 back in my truck bed, and cash it in for scrap..
