torque converter is loose. need some fast help
84CUCV
3/4 ton status
NJ for now
things in my driveway and in the way. its a 85 k5 with a 700r4. push it all the way in. it is lose. not sure why tho. is that normal for a 700? :confused:
my cucvs have a th400. not sut sure. we took it out to replace the flywheel.
thanks
Once the convertor is unbolted from the flexplate it will wiggle around if you grab it and try wiggling it. This is normal as the flexplate is what keeps it from moving around and the "nub" on the convertor centers into the end of the crank to keep it properly aligned.
