Bross82
I think I may have finally narrowed the noise down to being either the torque converter or the transmission. I checked the 3 bolts on the flexplate and they were all good (35ft-lbs according to the Haynes Manual). I also noticed the bolts on the starter were able to be tightened down more. But, I started it up with the dust cover off and it still makes the knock noise.... It definitely did seem louder with the cover off. But it was hard to pinpoint if it was specifically the torque converter or the tranny making the noise. Underneath the tranny and towards the driverside I though it seemed quieter. It seemed like it could have been louder next to the side of the transmission on the passenger side (near the circular shaped piece, is that the lockup part?). I tried the trick with the rubber hose to try and hear better, but I couldnt really tell any difference and could only get so close without the hose with the exhaust pipe there. It makes the noise now pretty much in any gear, but does not seem to make it when in neutral until I rev the engine.
Any ideas on which this could be and how to test? Also, does anyone know what is a good site to look at getting a new tranny or torque converter from?
Thanks,
matt
Thanks,
matt
