vdubnut
Registered Member
1991 burb 350TBI - 700R4 - 4:10 gears
I'm trying to understand the logic of the way my TC lockup works.
when im cruising on the freeway going steady the lockup is engaged.
If i then push the gas pedal down a little further the TC disengages.
If push the pedal down even further(pretty much WOT), then it downshifts.
is this how other peoples trucks are working?
here's my question...why would the TC disengage rather than the trans downshifting? the reason i ask is because when i am towing, my TC almost never is locked due to the extra power i am demanding from the engine. It seems like it should downshift rather than disconnect the TC lockup. The problem with all this is a concern about trans temps...
One explanation someone mentioned was that it was trying to reduce the load on the 4th gear clutch packs. But it seems to me that it would actually increase the load on them because its staying in 4th/OD and increasing the RPMS of the motor thereby increasing the load on 4th gear. Am i missing something?
