Some did have 6 bolts,diesel ones and HD gas engines too,used 6 bolt ones...I've even seen one behind a 292 in an old Chevy van that had 6 bolts..however,far as I know the bolt pattern is the same,and the 3 bolt ones will bolt up to the 6 bolt flexplate,using only three bolts...I think the 6 bolt ones had a lower stall speed,I know the diesel ones are a lower stall speed anyway....
