GsxrMike
Ok, I'm getting ready to overhaul my TH400 and wondering if I should replace my torque converter. I'm running a mild 350/400/208/4.56, trail only rig, I can't remember the last time I had it out of 4 LO and its fairly rare that I get to third gear. I don't know much about stall speeds but I run an aftermarket transmission cooler (the biggest one they had on the shelf at the auto parts store 5 years ago, probably 20"x12"x1") so I don't think heat will be an issue (I also have dual electric fans so I can keep air flowing across the cooler independent of engine speed. I've also got a transmission temperature gauge so I can keep an eye on temps. Most of what I do is slow rock crawling type stuff with the occasional muddy field or mud hole. My truck is probably close to stock weight, if not maybe a little under. I'm thinking with a higher stall converter my engine will spin faster while I'm trying to crawl up a trail keeping me higher in my power band and the only trade off would be heating the transmission fluid. Is this accurate? What kinda stall speed should I look into if I go higher? (BTW I searched but didn't find really what I was looking for) Also, what's the maximum transmission fluid temperature I should run before it starts breaking down? Also, any recommendations on tranny fluid when I fill it back up?
Thanks guys!
Thanks guys!
