73redblaze
i have a torque converter on the back of my 454 but i also have one attached to my trany. does it matter what one i use? they were both th400 but one is for a np203 and one is for a np208. does it matter?
there both in used condition. il just use the one thats already on there because im going to have to pull the trany off while its still under the truck so it would just be another pain to swap converters.
um.... um.... yea i was. but then how do you bolt the torque converter to the flywheel? becuase the motor is in the truck so i have to go under there and pull off the trany (which is going to be a pain in the a$$ anyway)? do i have to take the motor out?You arent leaving the converter on the flywheel and shoving it in that way are you???
what? i have no idea what your saying.. and why do i have to take the sparkplugs out?You take the flywheel cover off to get at the torque converter bolts. It could be sheetmetal or it could be aluminum. Turn the motor around with a flywheel tool or by hand with the harmonic balancer after you take the spark plugs out.
Tarey
i understand everything but this part
