Torque spec on 4 rear driveshaft bolts?
garydan
Port Saint Lucie, Fl.
Title says it all. I just replaced the output shaft seal and changed the fluid in my transfer case. I wanted to torque the driveshaft bolts down to spec. Thank You!
Title is very vague. What year rig do you have and is the drivetrain stock? Are you talking about the bolts at the rear diff?
I'm sorry, I figured it was standard. Its an 85 K5 Blazer with a 10 bolt. The rear driveshaft. Thanks.
Assuming your drivetrain is stock then you're talking about the 4 bolts on the rear diff yoke. Those torque to 15 ft/lbs.
