Was reading around and I wanted make sure this is correct.
20-25 ft lbs for ram horn exhaust bolts?
Tighten from inner two to outer.
Reason I bring this up is I had to pull the bolts to add anti seize because I forgot when I put the ram horns on...
Is it 20-25ft lbs dry in the Chevy manual? No antiseize?
What is the torque ft lbs with anti seize?
