Torx bit size for chev seat belts
surpip
1 ton status
sacramento ca
What size torx bit for the seat belts where they go into the side of the bed sides? I think its a 40 something, but i need to get the bit today and i cant remember for sure
It's either a 45 or 50. It might even be a 55. I don't remember though. It's been a while since I've torn the interior out of a Cavalier or S-10.
Mine were really tight too but I used some wd40 and a huge flathead and tapped it with a hammer while I turned it. I think I also used a flathead bit in a 1/4" socket for the passenger side.
fumes
focus
need the bit size, most of my tool are still in storage, and i have no such large flathead
need bit size
Thats it. I remember the damn screwdriver didnt work and I had to use something else.
Maybe try a cube of butter an old dirty mop and a BBQ stained apron.
Sig worthy again.:haha::haha::haha: You, sir, are a genius in you're own mind.
I think it is a T45 or T50. Although I am sure you have solved the problem by now.
absolutely without doubt T-47 is the correct Torx bit for GM seat belt bolts in these trucks.
I cross-referenced the GM tool number out of the manual last time this came up. I already knew, but there was still some disagreement. :)
balls
i just bought a t-50
well crap, i thought they went up in 5 increments, 45,50,55,60 etc.....
well i stopped at 2 stores, and saw no 47, just 45 and 50 so well see if it works i guess
