T
TankerCadaver
Guest
Hey all,
Well, we've had a few cold mornings here in the St. Louis area and for some reason my glow plugs wouldn't light this morning. As such I couldn't get her to fire.
I have an '83 - at least I'm pretty sure it's an '83. I haven't had it long and the seller initially thought it was an '82 but the title says 1983. Anyway I'm just mentioning that - isn't there a few differences in the glowplug relays and/or controllers between these year models?
The previous owner wired in an interrupt switch on the relay mounted on the drivers side fender well. The glow plug controller occasionally turns on the glow plugs long after things have warmed up... sometimes when flying down the interstate! So this interrupt switch prevents the controller from turning the glow plugs on.
I jumped that switch to make sure it wasn't bad - still no glow plugs turning on.
Then I jiggled the wired cap on top of the controller (directly behind the aircleaner assembly) and "click" I heard the relay turn on.
I cycled the ignition another time to get things warmer and she fired right up.
So I'm guessing the glow plug controller is goofed up to begin with (hence the interrupt switch).
I'm also guessing that maybe the connection of the harness and the controller needs to be cleaned/fixed/improved.
The previous owner mentioned that he upgraded the glow plugs with temperature limiting versions... do you think these could be the G60s?
There are glow plug controllers on eBay - does anyone recommend any other retailers?
Any help, observations or advice would be very welcome!!!
THANKS!!!!
THANKS!!!!
