Tow behind light wiring.
Wes Harden
1 ton status
Staff member
Moderator
Solutions
Lake Havasu City AZ
Am getting ready to tow a PT Cruiser behind a Bounder class A.
The Bounder has shared brake and turn. The PT cruiser has separate brake and tail.
I can find converter to convert a tow vehicle from separate brake and turn to shared, but not the other way.
I tried to wire a pig tail with a converter in it, but it bleed current to all 3 circuits, left right and brake, I think because I tried to use it backwards.
Anyone have any ideas.
I don't want to rewire the coach, our other trailers work just fine with it.
The PT cruiser was outfitted to be towed by our last Coach, but it was a diesel pusher with the same style separate brake and turn.
Yeah I got a set this afternoon at tractor supply while pup was getting shots at vet clinic. I'm a little distrustful magnetic lights. Going to look for away to add a secondary temp attachment, or at least something from keeping them from dragging on the ground.
I have been using them for 40 years. Even ran them on the Jimmy bumper because it was 3 feet past the semi taillights. Never had an issue.
