TX Toyota buggy
20180805_175515.jpg 20180805_175529.jpg 20180805_175537.jpg 20180805_175546.jpg 20180805_175553.jpg 20180805_175619.jpg 20180805_175632.jpg20180805_175733.jpg
1981 Toyota based buggy. lots of neat features on this rig. the hood is a cut down crown vic hood and has a prop rod, the rear basket also has a prop rod to hold it up while you change the propane tanks. it has a 22R on propane with a 5 speed into dual cases with 2.28 in both. Toyota axles with high pinions, 5.29 gears and Detroit lockers front and rear. 38" TSL's on MRW beadlocks. Hydro assist steering, Longfields in front axle. cage is 1.5 DOM. Warn 9500 winch with synthetic line. Marlin high steer arms and tie rod and dual case adapter. it is a 4 seater with Honda buckets in front and a Corbeau bench in back. it has a speedo but needs a cable to work. has stereo with amp and dual 6x9's in the rear and under the dash. I will say that this buggy needs a good cleaning and has a power steering leak that I have not messed with.Really don't want to get rid of it but I don't need 4 buggies.
asking $7500.00
