Toyota rims
pch858
Registered Member
Victorville, CA
okay I got another stupid question for you guys I'm looking to purchase some 80s Toyota 4 x 4 rims. I know the bolt pattern is the same 6 x 5.5 but why need to mess with the backspacing or change out the studs and get acorn lug nuts. Sorry for all the questions but I got a lot of them for this vehicle since Chevy GM products are new to me thanks for all your help.
They will fit if you want a wheel that small, looks like a 15x7.
You will need new lug nuts.
Back spacing is different than most chevy rims. They will work as in bolt on but if you got disc up front they may not clear the caliper. Mine did not. I just put some 2" spacers on, But I only use mine for the fitting into the garage/trailer wheels not my daily driver wheels. You can put a 33x12 tire on a 7' rim no prob
Also Toyota wheels will have a larger hub bore, so it will be centered entirely by your lug nuts. I run a set with no issues but that bothers some people.
