Hello,
So i am trying to find someone who has installed a TPI in a pickup to figure out a few vac line spots. The 3rd gen diagrams are kinda helpful but i figured i would double check with someone here to see what has been done.
My truck is a 1974 so no emissions junk is on my TPI. I have a MAP setup and it is running well so no issues there.
I need to find a spot to run my HVAC line as i am keeing my AC and heater. how is yours done?
Where do most of you have your trans vac line ran to? I have mine on the pass side of the throttle body.
How do you have your canister purge lines ran? I have a strong gas smell in the garage and i tink the vac lines not being complete is causing it.
pics would be great.
Thanks,
Tim
Thanks,
Tim
