Haha, cool! Just noticed the EFI forum now!
As Dorian mentioned, it does infact run now, but I still have one more timing related bug to hammer out, and then a whooooole lot of tuning.
I'm fairly confident that my problem is a bad knock sensor. Not only is it suppost to be used on a MAF setup with a `165 ECM, but it is also a cheap Napa repo.
Basically, I am getting a code 43, which is an ESC failure. When you first start the engine, the ECM immediately rockets the timing up in an internal ESC test. What it is listening for is the knock sensor to detect the pinging induced by the excessive timing. It detects this very quickly when the knock sensor is working, backing the timing off right away to keep the engine from being damaged.
However, in my case, it isn't getting any kind of response from the knock sensor, and after two attempts, it simply sets code 43, then limits the timing to what is specified in the prom, less any retarding factors that may be applied somewhere.
What this results in is very retarded timing that will allow the engine to run, and probally limp you home, but you won't be able to take off without backfiring through the exhaust, or with any real power.
I've confirmed the knock sensor's non-op status first by not getting any continuity in an ohm out attempt, and also by tapping on my pass side manifold with a hammer. The hammer should retard my timing to a significant degree with each hit, but doesn't.
Its been a definite uphill battle, but one system at a time, I am figuring things out. Since posting last, I also found that my fuel pressure was wayyyy low. Either it was a TBI pump that the ebay seller (sickening liar that guy...) tried to pass off as a TPI pump (gotta hand it to him, I didn't figure it out for almost a year and a half, LOL), or a badly worn out TPI pump. So, finally, my fuel pressure is good, air is good, and electrical appears to be good. Its just down to getting that timing (which has plauged me since day one, always had a code 43, MAF and MAP) working properly, then getting her tuned up
I'll keep you guys posted, and probally start a new topic devoted to tuning up a TPI as I figure it out, so other guys can reference sometime soon.
