morrisammo
Registered Member
I bought a 1985 GMC Suburban ¾ TON 4x4, , it’s in good shape. Little or NO rust.
The motor, well it starts and Idle’s, but it is rough, I have changed the plugs, distributer, wires, checked the timing. And did a compression check, but it still runs rough. And is not drivable.
This is the twist, someone whom owned it at some point in its life, had a Camaro motor put in it; I don’t know what year motor it is. And it has TPI injection from the now out of business Arizona TPI, at one time I do believe it ran well, but when I bought it, it had been sitting in a garage for 3 years.
So I’m weighting out what to do. Or what to get done to it. Seeing getting it running well, has stepped out of my skill/ knowledge range, and I need to bring it to a shop.
My goal is to have a super dependable vehicle that runs and runs, change the oil, do a tune up now and again and get 150,000 out of the motor, be able to drop in a re-build and run it another 150,000.
So the opinion I’m asking for is?
Should I have the shop fix the TPI and keep it as is?
Or should I have the shop, change it back to factory TBI?
OR another option?
OR another option?
