Well..here is a quick update. I have Spark to the plugs, which is good, but still no start which is bad. My thinking is that there are a few possibilities.
1) If the injectors are firing, then I am not getting enough fuel pressure.
2) If the injectors are not firing
- the starter wires are screwed up somehow and not telling the ECM to shoot off the injectors
- the injectors are grounded somewhere and no workie...
Any suggestions on where to acquire those little test noids? I looked all over town, but no luck? Also, do you guys mount a fuel pressure guage on the fuel rail? Anywhere else? Any particular brand or model work better, last longer?
, but today my little noid lights and fuel pressure gauge showed up so after dinner I had a couple of ideas I wanted to try...lo and behaold an hour later it started
....I was so surprised I turned it off and walked away...I came back and started it for a second time to prove it wasn't a fluke and then decided that it might be best to simply enjoy my small victory for the evening and come inside before I got too excited and broke somehting...Thank you guys very much for all the help and advice
...With any luck I will be driving by the end of the day Saturday...
