Hossbaby50
3/4 ton status
I got my TPI running yesterday as you may have read. Now I am trying to tune it and get it running well. I am having a problem with my idle. Once the motor runs for a little while (1-2 minutes) the idle gets real erratic. It dips, picks up, dips picks up, etc. The more it runs the worse the idle gets. It will eventually stall out.
I reset the TPS. It was at .570 volts and I set it to .508 volts.
My 0xygen sensor is not installed right now. Would this do it or contribute?
Also though if I rev the motor up (say 3K) and hold the throttle there the RPM will stay for a few seconds then drop down (2K) and pop up some and drop again, etc.
I am thinking my TPS might be bad but I don't know.
No codes are set though. (beside 12) and the check engine light doesn't appear while the motor is on. Thanks
Harley
Update:
I had the 02 sensor bung installed today with my new cat and everything seems to work correctly now. I have a little idle tweaking to do but it is running pretty damn well. I am a happy camper. /forums/images/graemlins/thumb.gif
Harley
Update:
