Tpi Vss
noahrob
Author
Santa Barbara
Hey Guys,
I know this is probably a very silly question, but can you take a look at these pics adn tell me if that is the brown wire from A10 I am suppoosed to splice into for the VSS sensor? I assume A1 is on the top left, on the side with the clip...same orientation as the pic, I counted over and three from the right is a greyish brown wire, but I can't tell where it goes...I was goign to run 12v from an "ignition on" plug to the VSS and then the other wire to A10...thoughts?
The connectors are labeled, I believe it's the blue plastic piece, it will have the "A", "B", "C" and "D" IIRC (each row is a different letter) and then the row will be numbered sequentially, also imprinted into the blue piece.
I'd trace the wire from A10 on the connector, you might already have the correct end, or at least a length already in your wiring bundle. The less splices the better. :)
Yes to wiring the VSS buffer to ignition 12V, should have that, ground, and then the "output" wire to A10.
