TPI............. what blocks does it fit?
uglychevyZZ4
3/4 ton status
Black Diamond, Wa
does TPI fit the older non TBI blocks since it was around in late 84? or was that the beginning of the new blocks? I am not sure if i should buy a complete TPI engine or just the tpi stuff..
It will fit any small block that doesn't have Vortec heads. You can buy a special manifold base that will make it fit Vortec heads, but the base costs BIG bucks. /forums/images/graemlins/frown.gif You have to do some machine work on the stock intake to make it fit pre-EFI heads. The angle on the 4 inner bolts is different between carb heads (used up until '86) and EFI heads ('87-'94 (or was it '95?), then the Vortec heads came out.
If you want to run it on a 350, be sure to get a TPI from a 350. The 305's have smaller injectors and a new set of injectors can run ya $200-400. /forums/images/graemlins/yikes.gif
If you find an 88-92 TPI setup you'll have to have a machine shop modify the 4 middle bolt holes in the manifold.
I found an '88 tpi setup, and got ahold of an '86 manifold so it will fit my pre '87 heads. /forums/images/graemlins/thumb.gif
Yep to get TPI to fit pre 87 motors you have to bore out those 4 bolt holes or find a TPI manifold from an 85 or 86 year motor. I bored out the 4 holes to make mine fit. It is a PITA and if I had to do it over I would take it down to the machine shop and have them do it. It shouldn't cost that much.
Harley
Hossbaby50
How's your running now that you've had it in for a while...
It has been running good for the most part. The only problem I have been having is it keeps killing ignition parts. A month ago I toasted a pickup coil, then a week after that a module. Yesterday I toasted something too. Haven't had time to figure it out yet though. /forums/images/graemlins/dunno.gif Once the ignition thing is ok it will be great. I am going to rip into it this afternoon.
Harley
