y5mgisi
1 ton status
Ok so, I never had a problem with my battery being dead in my '78. I could let it sit for 2 or 3 weeks and go out and start it right up. That was untill i found out my blinkers werent working and hooked up the conector at the bottow of the stearing coulomn that controls the blinkers, horn, etc. Now my battery dies within a couple days. So dead it wont even make an attempt to start. So how do i trace down the draw? I have a DMM. Should i disconect one of the battery cables and place my DMM leads between the battery and cable, then start pulling stuff apart untill i get a 0.00 reading on the DMM? if so what setting would i use?
. Repair what you find and reinstall the cable.
