Tracking down running light problems
BS_k5
Registered Member
Loveland, CO
Ok so my left running lights, like when the headlights are on, both the front and side ones, will not come on when I turn the lights on. I know its not the lightbulb because the blinkers work when the lights are not on, which tells me it also is not a bad connection at the bulb. Both of them on the right side work fine. Any suggestions?:confused:
I'm pretty sure the front ones are dual filament bulbs. Not sure about the side ones.
A dual filament bulb could have the running filament blown and the blinker filament work fine. So, either grab a new bulb, or swap it with the other side.
If the blinkers only work with the headlights off, then most likely a bad ground.
If its not the bulb, post back with more info. Make and model of truck, etc, and we will try to take it from there.
J.
Correct it is a dual filament bulb. Its an 84 K5 custom deluxe. I kind of figured it wasnt a bad ground because there is what appears to be a ground wire attached to both the left and right lights that goes into the dash.
Oh and I pulled the bulb out to check the filaments and neither were broken so does that mean I should rule out the bulb?
Nope, odds are its good, but never go by looks. Easiest way is to just swap in a known good one. The one on the other side is the closest.
As for the ground, just because the wire is there, does not mean it has a good connection. Also, the socket can have the ground go bad inside.
Swap the bulb first, and then we can check more exotic things.
