I am going to build a cheap, yet effective set of traction bars to eliminate axle wrap. I wanna put them where they are out of the way. My plan is to use 3'' axle link tabs, flat link tabs, 7/8-14 x 3/4 heat treated chromoly heim joints, and tube inserts with 1 3/4od x 1 1/4id tube and make them roughly 40 inches long with a bolt on cross member right behind the transfer. I can accomplish all of this for around 170. The problem i am running into right now is trying to figure out if i could put the axle link tabs on top of the axle tube, or if they have to be below.
